7800RPM rev limit is useless on a standard engine. It's way over the point of peak power and all you are doing is making noise and reducing engine life. The standard cams make no power past 7K'ish.
i don't know much about these things, but would any tail off in power be overcompensated by then changing up a gear and ending up 'futher' into the power band?
so where is this group n setting then? Whats the file name?There was when i did mine,i ran a 98 ron (or 95 not sure that long ago since i did it) then after a month changed to the group n setting to compare and hav'nt went back.
