Where are my wires? =/
aucky
Car  N
Right,
Im going to try to wire up my rear speakers tomorrow as my clio is poverty spec.
I took the rear door cards off last night to see if the wiring is already there. No such luck, Unless its any of these????
Do i need to install wire all the way from head headunit or are one of these the rear speakers and they'v been tucked away somewhere??
Any help is greatly appreciated! =]
Thanks..
on the left block the outer 2 on either side will be the rear speakers,use them if you really cant find them in the door
Thanks,
I had the rear door cards off and the only wires were bunched together and running over the arch and to the lights etc =/
Renault magic wires =]
Thanks,
That makes sense and kind of ties in with what MT AUDIO said.
Also save me asking another question about fitting crossovers =]
what does the plug in your secod pic connect to as the plug looks strangly like the plug for the speakers. although the wire colours dont seem to match the iso block.
the wire colours from the block ive never known to be the same colour throughout the length of the car unless theyve been replaced
Its just above the seatbelt retractor (behind the rear door card)
