Painting Bullets (yes another thread!)
Stripped it back to standard with the thinners, cleaned it thoroughly and sanded it before primer.
Now the primer is drying out unevenly/rough at the edges :S
did you use plastic primer, as i 1st used normal primer and that was useless so bought some halfords plastic primer and it worked a treat.
this has been sanded back to bare plastic with 2 coats of plastic primer and 2 coats of normal primer on top, going to spray some colour on it today
Yeah plastic primer is all I have
Got it all at the same time in Halfrauds lol :)
Cellulose Thinners, Primer, Paint, Lacquer & Leveler
Sorry guys but how do the bullets come off and go back on ??
would like to do mine soon.
bump?
I'd also like to know as it seems a good enough day as any to sort them out! Had a look briefly but I don't want to snap the clips so presume I have to take them off from inside the doorcard?
These look awesome!:cool: There's some good money to be made doing this! Great job and quite jealous!!!
bump?
Ease them off with a flat screwdriver covered with a soft cloth so you don't scratch the paint
- can be stiff sometimes until you pop it out but they will come off without brute force :)
Oh I meant to say - don't go mad with the lacquer!
I got to that stage this morning and kind-of messed up 2 of my wheel diamonds :banghead: but hopefuly I'll be able to put them right when they're dry.
Bit stuck lol YES AGAIN :rolleyes:
When you primer-up the bullets and get to the painting stage, how do you paint the bullet without painting the lettering, and vice-versa? :)
iirc if you want colour bullet with the standard lettering paint it and then just rub off the lettering straight after! :)
doesnt work as it always leaves a raised edge, which will eventually crack off.
best bet is to paint them with a small brush, or to mask them if youve got enough patience
if you still havnt had a go at doing your bullets mate i can do them at work for you for a small price! check my threads! done many bullets and badges for people!
