1.2 16 v clutch
Car  1.2 16v Dynamique.
Hi folks. Need to change the clutch on my mk2 ph2 1.2 16v and just checking that I can do it with leaving the engine. Back in the day when I was a technician in the motor trade, Clio's had to have both engine and box out but just want to check with you experts first :approve:
Thanks
iirc the willys and 1.8 16v's the engine had to be lifted. There a peice of piss on the 1.2, everything is! Drop the subframe and your away.
you don't even need to drop the subframe when i changed my gearbox and clutch i did it through the top it's a tight fit but does go through.
thanks carl
thanks carl
I was wondering if you could do that actually. Get the box out just enough to get the clutch and bearing done. Would save me taking the sub-frame out etc.
Also, does anyone know off hand what the correct gearbox oil is for this car ?
Thanks again
Your not wrong there ! Everything is so easy to do on this car. I have my brothers Mk2 Ph1 at the minute and was thinking of buying it off him. Its rapid and looks great in black :D
Clutch out now. No need for sub-frame to come out either. If you remove the two studs which the box go over (for bellhousing nuts) the box comes back enough and gives you a good angle to take the clutch and thrust bearing out comfortably. I love 1.2 16v's. Not quick, but so easy to work on !
