1.2 16v starting fault
Car  Ozzed Clio
when startin my car it judders as if to stall but dosent stall. it is like on the old cars when u hadnt pulled out the choke enough. when it has done its little hissy fit it drives fine. any ideas?
i changed the coilpack, leads and spark plugs but its still doin it. only happens when u start it and settles down as it warms up
been trying some things to see if it cures the fault and found that it i press the accel pedal a bit before i start it then it dosent happen. im puzzled???
mine did the same thing and i just took the throttle valve out cleaned it up and its been fine every since. I have also done it on a few other cars and it has fixed it. seems to be a problem with the 1.2 16v it just seems they get coked up.
where do you find it mate. sounds good to me, will give anything a go ryt now as it is gettin to be annoying. put a pic up if ya can please :)
mine did this, was a t**t to start always juddery but then once it started it drove fine.
Turned out to be the head gasket, probably not what you wanted to hear!
mine did this, was a tw*t to start always juddery but then once it started it drove fine.
yup mine has just done this, gone kapoot today
