Yozza Exhaust help and new bullets
Car  Bumder With A Buffer
Yep another media thread tonite :)
I currently have a Yozza Race System on the Monaco and basically I want to get it raised up into the bumper as its looking a bit s**t from a distance
Latest photo taken tonight..Yeah it needs a clean and polish!
And some older ones
See what I mean it hangs down a bit?? So I wanted to know if its easy to have it cut into the bumper or if its worth doing that??
From looking underneath all id need to do is loosen the bracket around it and lift it up then re-tighten??
Also had a play with my spare bullets not finished yet though
I cut the recess into my cups bumper a few weeks back to recess my exhaust. Firstly worked out where the exhaust would sit in the bumper. Secondly I marked out the recess (using the trim as a template), cut the initial recess using a tile saw with a tungsten carbide blade (1 or 2 mm in from the final edge). I finished it off by filing the remaining last few mm off until the trim fit, then pivoted the backbox round, where its attached on the centre section, until it fit in the recess. Final result can be seen here :
http://www.cliosport.net/forum/showthread.php?t=411288&highlight=piper
yeah you can get it up so its just touching the bumper, but you won't get it up into the bumper, the centre section is too high, you'd have to modify the backbox
Got the same exhaust on mine and i hated the way it sat so i got mine up into my bumper
took it to longlife exhaust and they changed it but still keeping the great sound
which i was bit worried about losing heres a few pics
May just replace the mounts as my one is shot to bits.. get it as close to the bumper as possible.
Tbh I think once its pulled up so its sitting directly under the bumper it will look a lot better.
Also - get that car cleaned! :rasp:
