Martin_172
		how often do they need rebuilt
how much to rebuild
			how much to rebuild
I'm guessing your car stan* is only used on track, wounder how one would fair with normal road driving
well the sadev would be designed to be abused, but would it be designed for changing gear when not giving it the beans?
I dont know why you would fit one to a road car tbh...
Ratios arent ideal, not the smoothest thing to drive round town, quite expensive for no "gain".
Std boxes are fine for the road...
sadav boxes are quite good to take to bits yourself tbhand actually not whiney or clunky alex :rasp:
get away with you, with itb's on you will never hear that![]()
Clunky and whiney, not ideal for road use imo.
talking 3.5k+ +all the bits to make it workHow much are these?
Stan, Rednax and DanD - Thanks for your advice/opinions and serious answers. much appreciated.
ollie 1982 - if you dont have anything proper to say then dont say it maby i should have been more specific, im buying another dci clio this week and now the 172 is going to be my weekend track and ocasional road use toy to go all out on, and im either considering fitting a sequential box or selling the car and buying an ex cup racer
your attitude imo f**kin stinks considering you are an area rep which should make you a more respected member of the forum but yet i ask a serious technical question and since you dont know the answer you decide to assume i want a sadev box to race about the streets like a hooligan now apart from the fact it would make the car the ultimate "traffic light grand prix" car with short ratios, quick changes and an LSD its not really my thing
Mike1Pow, as above, if you dont have anything constructive to say, dont bother.
peace.
talking 3.5k+ +all the bits to make it work![]()
peace.
be an awesome mod, apparently the cup race cars running relitavely standard engines but only weigh 900kg with a sequential box can do 0-100 in 10.5 seconds i beleive! think they top out about 120mph! lol
I dont think your seeing the bigger picture here. Like you said they weigh only 900kg's. Thats one hell of a weight saving and advantage plus its not just down to the shift, its the difference in gear ratio's mainly.
If you want this for acceleration then change your stock ratio's and save yourself thousands![]()
I can vouch for that.X85's weight nigh on 1100KG's with driver and will crack 0-100mph in 10.5 seconds.
Its massively down to the shift time as well - the mechanicaly actuated Sadev ST75 on the X85 will complete an upshift in around 85ms from the point at which the drivers movement on the shifter actuates the gear cut to the point at which the cut ends and torque is reapplied. Try getting an upshift done in 85ms with a synchro H Pattern. 500MS and you're doing well.
The ST75 is a tough old box. We've got the highest mileage X85 going and so far is 14,000KM's have had 1 Set of dogs, 2 input shafts and a pinion. That's on a 24hr endurance car that takes a hell of a kicking when its out and about. The only thing that'll really wear them is poor gear cut/gear control.
M
the box mounting is the same???? eh? completley different on the racers, engine and box is mounted to the subframe
i'd speak to k-tec and find out how they did it
Hutchies quoting how much mine cost.Not a f**king CHANCE! Box alone is 6k +VAT IIRC.
They are strong box's, the diffs become quite weak after a while though. SWR rebuild them for the cup racer teams but we've had endless problems with the last box they did.
ON the X85 the mount is on top the same as a normal road box so SHOULD fit standard mounts, I dont know how you'd get on flatshifting though as it's quite harsh.
sweet stan cheers ill look into it see if any pop up, im thinking buying a full ex cup racer might be a better option. did they do RHD ones or are they all left?
