Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
with my current engine looking knackered, ive looked around for a replacement, my q is, can/a K4M be used in place of my E7J? straight swap or fabrication needed?
No - its not a straight swap. The E7J is a 1.4 8V engine and the K4M is the 1.6 16v. The wiring loom / ECU will be different. The gearbox will fit and so will the shafts. Personally i would buy K4M 748 out of an early 98 / 99 clio 1.6 16v along with the engine wiring loom / ECU / Plip key / UCH and chassis number off the donor vehicle ( this will help if you ever need an immobiliser code to programme the ECU or order a new key ) . The dash loom will be the same so no need to change that.
Thanks for the reply mate. I'll take that onboard. atm I'm thinking if i buy parts and let garage repair (mucho £££) or swap same engine out/in myself/stepdad if its cheaper (probably, seen same engines from 100-250 on ebay but travelling could be a b**ch.. renault engine place 5 miles away but they want 350 for one.) or like you said i wouldnt mind that either.. one extra query whats an UCH?
