Building a PC...its been a while!
Car  SchwepTek™
Since moving to mac i have completely got out of touch with the PC side of things.
I am now looking at building a Media Centre PC but can't decide if i should go small form factor (micro/mini ATX/ITX) or go standard ATX so that i have the option to upgrade.
Can the smaller Mobos take decent graphics cards?
Also any reccomendations on what to get?
I have been given a C2D 2.6ghz processor and 2gb DDR2 RAM! lol
not the mobo you should be too bothered about, as long as it has a PCI-E 16x it will be fine. The case size would be your issue. Most of the high end cards are massive and also require around 600 watts+ over power! they get hot too so cooling can be an issue with a small case.
Id go with a cheaper gfx card, something like 8500GT (geeforce) 512mb version as that would be fine in a small case.
i've got one of these cases for my media center pc
as it shows you can have a beefy graphics card in it too
As far as media centre PC's go, look for something with integrated GMA950 or GeForce 9300 graphics. You don't need something external for that!
check the clearance before you buy as well, couldn't get the cover on mine cause the heatsink was in the way :o
I would have thought both of the above would be good enough for a media centre PC. :)
D.
