sqeaks and rattles
  clio 200
the 200 is riddled with squeaks,rattles and clunks already.not impressed!!
had my 197 for 20k and was very well built. feels like im back in my ST lol
  clio 200
knocking coming from he suspension which renault tells me is nothing :S
really annoying vibration coming from dash between 3500-4000rpm and again about 6000rpm
a rattle from the cenrte console and another from my pasanger door card i think :mad: its driving me mental lol
  clio 200
thats wat im thinking about doing,scared incase they take it all to bits and its worse lol
  BG182®
Back to Renault, sit down and say your not happy with it, and don't move.
Do just as he says.
If you suspect something is wrong don't leave the court till you have it sorted.
You've payed for a car which you expect to be worth every penny.
Go in, be brunt and tell them how it is :cool:
  S3, Polo
Shame on the 200, get it back to them and stick to your guns!
My 172 with coilies and uprated engine mounts doesn't rattle much, just a glovebox door that makes a sound like a cricket at idle!
Greeny.
  440i + 182
God that must be annoying on a brand new motor :( Mine rattles like f**k but I would expect that as it gets abuse and the coilovers dont help with the rattles!
As above though, go in and have a firm word
  GTD, Lupo
must just be yours. I only have one bad noise coming from mine and its a funny popping and puffing noise from the exhaust when idling
Paul
  clio 200
its going back in next week i think,its the buzzing fom the dash that gets me the most and the knocking from suspension,yeah ill be having a word or itll be going to another garage for its work from now on
From what I've read on here, you're better contactin Renault UK direct about any warranty problems. Dealers, being dealers, are pish.
  clio 200
might try that ill give the garage 1 more shot at sorting it
good news is that the ratle from the passenger side has decided to sort itself :)
  197 F1 R27
Can you elaborate on the suspension knocking? I get a slight knocking from my steering column when turning in my street and also on some corners. I think this is a common fault. Its like a very small bit of movement which is felt through the steering...i had similar rattles to you aswell. Pain in the backside it was, but i took the car to a good dealer and they took it all apart regreased around everything and put it back together. It certainly did the job as mines solid now.
  197 F1 R27
p.s you may find rattles are worse in rain and cold weather. Im just guessing here but im sure the technician said to me that in hotter weather the plastic expands more so rattles less.
Steve
  LMC10, Puma E
You gota love renault bullshit:D
-6 to +32 mines fine so do see what temps have to do with it.
If the interior squeaks & rattles now it's only going to get worse, fact:mad:
Gaz_
  Extreme mode
That slight knock is the track rod end (inner joint). Mine does it. Very common on the passenger side for some reason!!!
  LY V6 & Fiesta ST
Only problem i have with my 197 is a slight rattle from the glove box which i found out yesterday was coming from the set of locking wheel nut key/bolts i have in there.
  clio 200
the knock is coming from the driver side i thought it was top mount or anti roll bar bush
its on the rebound after hitting potholes or a bumpy road etc,goes away after about 40mph or so.so im reckoning its soething that can keep up as the bumps get quicker if that makes sense lol
