If you already have a dish then it's a case of coaxial cable from the LNB and connect it for the respective F type satellite input on the TV.
I assume there's a set-up feature in the tv menu somewhere.
You're a man. Press buttons on the remote until something happens![]()
If you've already got a dish up then you should have a coaxial feed into the house. It will be a cable with a metal connector on the end that looks like this -
If so connect it to the TV and assuming the dish hasn't be moved and is still working your skills on the remote should result in Freesat.
you just need some ct100 cable and two f connector ends b and q will have em
make sure its ct100 cable not rg59 both look similar but the ct100 has a screeen and is for satalite installations
id just by cable with f connectors already attached. Dont bother pissing about.
(i'm uber lazy)
http://www.argos.co.uk/static/Produ...cessories|14419521/Trail/searchtext>CABLE.htm
Ample.
