Aerial box to remove need for a proper aerial??
Pep
Living Dangerously
Car  M2,XJS,S1000RR
I have been told it is possible to buy a different style of aerial which is just a small reciever box that can sit in a window etc, connect upto the headunit in the usual way and receive the signal..
Anyone heard/seen/know where to get one?!
Funnily enough, I was removing the Audio stuff from a Golf today and there was an ariel lead that was powered by a looped live wire from the headunit. It never went to the roof of the car (standard ariel placement) but to a long wire that was stuck to the inside of the windscreen. So small you couldn't even see it!
P.s, I removed all of this stuff as the radio reception was utter garbage and refitted standard stuff. Much better! lol.
Gutted.....really wanting to get rid of my aerial and have it welded and smoothed over....
Was kinda secretly hoping that!
Just need to find out where to get one from...
maplin sell internal window aerials dunno how good they are but yeah it will look alot better
Could someone on a car audio forum ask for me?! pleeeeeease
Have you tried MT Audio on here? (I think thats what he's called!)
Failing that, pm CrazyClio, he's on a few Audio forums.
Tried Matt yeah, he said hes never heard of them, which gave me little faith, but knowing you have/had one has brightened me up a bit!
Need to sort something as cant get the car sprayed until I decide either way!!
I know Vauxhall Omegas have them as standard, our 2 did. The older one buggered up though, ended up being impossible to get a radio signal and have the heated screen on at the same time.
well the standard one on my e46 works 'ok' youll never beat a mast on yer roof but the window ones suffice
What kind of wire is on the aerial?
Is it just a single cable running to the back of the headunit?
Could I effectively make my own?!
cant find them with maplin now, could make your own its only copper tape in the window, 2 pieces
Yeah seems from a bit more research it will need power....
Hmm, need to sort a new headunit out too so I'll have to speak to someone about it, probably bass junkies or something...
I remember our old XR3i (back in the day) had no roof aerial, it had an internal window mounted one and we had no problems with it.
lmao i put one of those on my custom moped headunit funnily enough worked pretty well tbf
