slight misshap
Car  clio 200
little story for u lot on here
had a fiesta st500 b4 my 200,and about 3000miles into ownership i stuck a k&n typhoon on it along with various other mods
after a work night out was taking my m8 home and hit a puddle (river) about 2ft deep about 10ft across,bent somrthing managed to drive to 40odd miles home then this happened in the driveway
sum pics
and then
lol no well hope not,the filter sat right infront of the passenger wheel which didnt help matters
it split the block from sump to head nearly
definitely hydro-fucked. lol. after seeing you've said the airfilter is right by the wheel arch. engine sucked a load of water. water can't be compressed. cracked ze block.
i know about hydrolocking (the engine wouldnt crack from change in temp that badly) i would of expected rods to bend or snap or blow out the side rather than it just crack like that!
hydrolocked,bent or cracked a conrod and held up for a bit then it gave way and split the block. ford sorted it under warranty ;)
I mean, after the engine went pete tong, did you put the standard airbox on before it went to be repaired?
hang on u hydro locked, bent the rod or what ever and still drove on it??
thats wat ford said had happened?
i still needed to get home so just drove it,thought being a ford it might just sort itself lol
yeah i didnt think they would of since it was water damage but they just went on and did it anyway lol
nice one, bit of a result!
Water is dodgy as fcuk, I'll never settle for tyres that are crap in the wet
exactly, I aquaplaned off the road near Newton Stewart at maybe 30mph when I hit standing water in my 182, sh4tpank!
Renault certainly wouldn't. They barely do the things that fall under warranty, let alone any extra-circular work!
to be honest renault done everything i asked of them when i had my 197
including replacing lamda probe in the exhaust 3 times,because the car was lowered the car scared its arse going in and my drive,in turn fraying the wires going to the lamda probe so it didnt work lol
