i have a ph1. the rear wiper blade is knackered and i need a new one asap. Can i fit a new blade of do i need a whole new arm. iirc these are different from the 1*2 wipers?? cheers
What phase 1?
I assume it's a 1.2 mk2 ph 1?
I have a mk2 ph1 1.2 and you can just change the blades, turn so the blade is 90' to the arm then push the blade down the arm and it should pop off the clip. At which point wiggle the blade and it will come free off the 'hook'.
