buzzing under hard cornering - engine mount?
Car  172 ph1
I'm getting a buzzing sometimes while I'm on track, but only when I'm on the throttle and cornering hard in right hand turns, with the front left under a lot of load. The engine mount on the left side has not been changed while the engine mount side on the right has.
Does it sound like an engine mount issue, or could it be the left driveshaft CV joint?
Check the exhaust mounts as well as mine was swinging around on hard corners causing a similar problem.
