how do you remove the back of a clio key? its a mk2
I iimushroomzii Toilet roll king Transit Connect. Sep 1, 2009 #2 Push it up? Make sure there's no keyrings in the way
The Dan Grenade ClioSport Moderator Whichever has fuel Sep 1, 2009 #4 Put another key in the hole and use it as a lever.
AhmedRSi ? Sep 1, 2009 #7 Daniel said: Put another key in the hole and use it as a lever. Click to expand... As above, or a long screwdriver
Greeny. ClioSport Club Member 440i + 182 Sep 1, 2009 #8 I did mine last night, was really tight but does move when you push it up.
The Dan Grenade ClioSport Moderator Whichever has fuel Sep 1, 2009 #10 The hole at the top where you loop the key rings through
X xxxic3xxx clio mk2 p1 1.4 16v Sep 2, 2009 #12 does the keyfob need re-syncing witht he car after a battery replacemnt? if so how?
