burning mp3 cds
Car  Vantage
what is a good software to burn mp3 audio cds?
every time i burn albums (different folders) using wmp they get mixed together in the same folders:(
Well normally i just sort out the stuff before i burn then burn it all onto disc.
Nero Express (the latest edition) and i just use Nero Burning ROM for other stuff.
Windows Media Player, create a media disc and it leaves the disc open so you can add more MP3s.
Rather than create a music cd
I don't use any program.
Drag and drop into a folder. "Burn to disc" and then select data CD.
Done.
Ever seen that film Contact (yes it was s**te), good line from there springs to mind right now
have you ever heard of Occams Razor? its a general precept that all things being equal the simplest solution to a problem often turns out to be the right one.
QED motherf**kers :)
:S only works on rw cds?
Not creating a data cd. It doesn't close the cd so you can still add more to it but you can't write over the data already burned.
PS. Reading my comment now it's a totally random comment in relation to your question! Blame the alcohol :o
