Door cards
  lift number 1 @ btm
streamline carbon :approve:
  172 gravel rally
did you cut the door shell to fit these? I looked at fitting a flat panel but the center of the door had metal beams that aren't flush with the outer edges. Did you make them yourself or are they an off the shelf item?
  SQ5
Yea ebay, performance-trim.com do. No where near as expensive as streamline I'd imagine. Also can cut out the holes you want. Although to get to Brisbane, it may take a little while, UK lead time is 10 days!
  lift number 1 @ btm
the cards are held on with sticky back velcro, there is no cutting of any panels needed to fit them either.
they are supplied finished and ready to go.
they are also mega light, as they are about 1mm thick :cool:
J9HHY
  172 Silver Cup
Can anyone answer the above? Can't see how to get them flush too!
