did you cut the door shell to fit these? I looked at fitting a flat panel but the center of the door had metal beams that aren't flush with the outer edges. Did you make them yourself or are they an off the shelf item?
Yea ebay, performance-trim.com do. No where near as expensive as streamline I'd imagine. Also can cut out the holes you want. Although to get to Brisbane, it may take a little while, UK lead time is 10 days!
the cards are held on with sticky back velcro, there is no cutting of any panels needed to fit them either.
they are supplied finished and ready to go.
they are also mega light, as they are about 1mm thick
