Sport to non-sport wing size difference?
Car  R5 GTT EFI Clio.
I am going to be putting a 182 front end on my clio and same for the back, just wondering if the wings on a 182 are the same as my 2002 Mk2Ph2 1.2?
Hard to tell? They look quite a bit wider to me :S
I could be completely wrong
Only that the wings will look weird if you don't get sport side skirts too! Think you need sport arch liners too as they are different to non sport ones.
you need bumper, wings, sideskirts and arch liners for a flush fitment. they all fit together. if you wanted the proper full kit then you will need to buy sideskirt clips to fit the sideskirts. the clips are bolted onto the sills and the skirts just attach to the clips. then you bolt the bottom part of the sideskirt onto the sill.
however if you wanted to fit replica skirts with standrd wings then you would just need to tigerseal them on. you would also need to cut a bit of the bumper bracket so that it fits onto teh standrd wings.
iv done both ways and its best to do it properly with the sports wings
i originally did my skirts as per my guide http://www.cliosport.net/forum/showthread.php?t=336465
but after a while they started to come away so i bought some sideskirt clips which pop rivet to the car and they fit so much better now
before:
after with clips:
you may want to browse through my progress thread http://www.cliosport.net/forum/showthread.php?t=327434 i wrote the how to guide for modifying the bumper to so if you need help just ask.
one thing i did hear from a bodyshop was that if you swap the wings then you will need to paint the bonnet it blend it properly. obviously the factor option looks better but the cons are you have more parts to buy, they are official so more expensive and you then have more parts to paint.
Jungle Jim they are non sport side skirts. Is it not different if he gets sport side skirts as they go onto the wing
i was posting that in reference to just tiger sealing the skirts on
and even the proper skirt need the sideskirt clips rivetted to the car. i think i only used 5 on each side or something like that, you can use a load more. technically the clips are just a wedge which allow the lip of the skirt to clamp between it and the body of the car
as you can see on this pic
Don't forget that depending what wheels you're running you'll need spacers aswell or it'll look sh*t.
Yeah, im going to use the 182 wheels i think, Thanks for your help guys, i know my local scrappy has one sport in and i think the rear bumper is ok, will go look tomorrow, Cheers, :P
