Coaxial Speakers in Doors?
Car  1.6 Ford Focus
Just thinking ahead really but I am planning to replace all the speakers, apart from the standard dash tweeters, which leaves me with a small question regarding tweeters.
Almost all speakers I find have a normal mid range speaker with a tweeter built into the middle... Would this not just throw the balance right off? It would work out to 4 tweeters, 2 door speakers and 2 more speakers in the rear.
Im thinking that would give out way too much high tone sounds...
You'll realise that they're not that good once you've put the new ones in... and they're easy to fit (if they're just the top of dash jobs?). Twist the cover and lift off, and a simple swap over... that was on a ph2 though and to be honest not sure if it's the same set up on a ph1?
