Stripping for Fuel Efficiency
Jamie
  Audi B8.5 RS4 & 200
Not done it for fuel gains but my 172 did record higher no's on the trip with spare and rear seats out.
  audi a6 3.0tdi
It certainly works, i did it for weight loss but on a fast road trip round wales i recorded 39mpg in the 172.
Poopensharten
  Golf R
If it was a V8 maybe.
Clios arent exactly bank breaking to run.
My Phase 1 172 returned 44mpg to Newcastle and back with the full interior and a stealth exhaust on it.
Not worth the hassle
Scrooge
  E55 AMG
I wouldn't bother either buy a diesel or just be more carefull. I would rather pay the few extra pennies for a quieter car to be honest
  328, MK1 Clio 1.4
TBF it sounds like the worst idea I have ever heard,
You want to strip a 1.2 that is your daily runner, doing 65 miles a day, to save money on fuel?
Right . . .
As silly as it sounds, a remap and strippage has significantly increased my fuel economy.
Driving fairly sensibly before returned about 290-300 miles a tank. Now I can get 340ish.
  328, MK1 Clio 1.4
To make it worth while and to notice a worth while difference, you would have to strip it properly like this:
Just taking the back seats out isn't gonna make any noticeable difference to mpg. And I wouldn't want that ^^^ as my daily run for 65 miles.
As I said, buy a diesel.
  audi a6 3.0tdi
My diesel regularly returns 50+ mpg but you have to take into consideration buying it in the first place. He's already got the 1.2 so there is no extra outlay of cash and saving weight is free.
  White clique
as an example if i have a passenger in the car who is lets say 75kgs, i dont recall getting a lower MPG (and i do track this sort of stuff for work fuel expenses etc).
It would probably make a tiny difference, maybe tenths of a mile return or something.
Poopensharten
  Golf R
Really? I do 65 miles a day, and I get 30-35mpg. I'd call that pretty bankbreaking for a 1.2.
Thats pish economy matey.
Realisticaly, you take the spare wheel and rear seats out, whats that going to add? 3mpg? Hardly worth it tbh.
Sounds like you need to service your car and maybe adapt your driving habits..!
Check the tyre pressures first, I 1.2 shouldn't be reading that low, unless you're sitting in stationary traffic or hoofing it in first gear everywhere.
  328, MK1 Clio 1.4
Not even that TBH, would be under 1 mpg, they will weigh less than a passenger as Alan has said.
Jamie
  Audi B8.5 RS4 & 200
It makes a reasonable difference actually. If you hammer your car you can significantly tell the performance difference (well I can) and it's the same on fuel.
cat171
As said drive more economically. Also read the road a bit better, the less time you have you have to be on the brakes the better (don't crash though) Also change gear moreoften, don't let it labour in gear etc.
If all that fails, buy a derv mate.
  PS 200
Adjusting your driving will have an marked effect on fuel efficiency.
Losing a few kgs will have limited (if any) effect.
Tighten My Nuts
Definitely makes a noticable difference in my opinion.
Consider this...
When maintaining a constant speed all the engine has to work against is wind and rolling resistance, therefore uses next to bugger all fuel unless you're on a motorway.
Accelerating however, uses masses of fuel as the engine has to haul 1,000 kgs plus up to a higher speed.
Any weight saving at all will have an effect as the engine has less work to do when accelerating.
My Cup has had 120kgs taken out of it, and I rarely get less than 40 mpg on a run...and close to 45 mpg is not too much of a struggle.
As above though, you can make a fairly easy 5mpg gain by altering your driving style, and avoiding the middle pedal as much as is possible.
  Nothing at the mo :(
I got 40mpg today according to the trip doing dual carriageway and some town for about 20 miles... never went over 3k and feathered the throttle :D so dunno how your getting a worse reading then my 182
  330Ci (Fail)Sport
It should make a difference, whether its a noticeable difference is another thing. You'll probably only make an extra couple bhp/tonne which I doubt would affect mpg much.
I used to get 30-33mpg in my 1.4 8v, mainly suburban driving, odd motorway. Got it up to 42mpg in rush-hour driving on a-roads at constant-ish pace purely because of the way it was driven. I was a lot more gentle with the right pedal and kept a larger distance to the car in front so didn't need the brakes as much.
As said by a few already, driving style will make more difference.
  dCi 65 + C2 (<Sold)
Didn't say I was going to do it, just wondered if anybody had done it.
I'm a seriously economical driver. What do you think I do, stay in 3rd gear on the motorway?
Never go above 3000rpm on gear chances, travel at 60 all the way and back, anticipate traffic, never coast always go down the gears when stopping...not much else I can do really. Just not an economical engine.
And my car gets serviced twice a year. ;)
  Ph1
You must have a problem with the car because that mpg figure for a 1.2 isnt right?
Should be more like 40's to 45mpg average figure.
Could be a lambda problem? low tyre pressures, blowing exhaust...etc etc
  Ph1
Non 16v is pretty much the same, 0. difference here and there thats it
Just because you take it to be serviced twice a year dosent mean theres no problems. That figure you quoted is not right. Maybe your trip computers out ?
Only way to do a accurate mpg test is to calculate manually. Have a look on google for the calculations
  Renault Clio S
So what's the art of driving to maximise fuel economy?
I’m facing a 200 mile roundtrip this weekend, a journey I usually make around once every couple of months in my 1.4 (8v). If I have the patience I will try and keep under the 3K rev limit at a steady 65-70MPH for the entire journey, other times I drive at 4.5K rev limit at around 80+MPH. My car doesn’t calculate the average MPG, but in both cases – going by the fuel gauge which I appreciate isn’t necessarily accurate, I usually use up a third of a tank per 100 miles.
  dCi 65 + C2 (<Sold)
Arent you better in a diesel Clio then?
Course I would be, but the reason I have a sh*t 1.2 is because I can't afford anything better. My dad's SUPPOSED to be letting me buy his DCi 65 off him at a very reduced price but he needs to get it fixed first, something that isn't very high at all on his 'list of things to do'.
Poopensharten
  Golf R
I feel your pain mate but as the saying goes, gotta start somewhere etc
People will say that unless you do X amount of miles in a diesel the diesel cost does not warrant the economy but as you said if your old boy is going to give you a good price it might well be worth it!
  dCi 65 + C2 (<Sold)
Aye I worked it out Danny, I'd be saving £1500 which would be less than the car itself plus the £35 road tax I'd be breaking even on the first year, then every year after that I'd be saving £1500 (excluding maintenance and insurance).
Just hope he gets it fixed soon as £3000 p/y on fuel sucks!
I used to get 22mpg from my 172, this week I have driven properly driving in fith doing 30. Im now gettin 26.3mpg.
Although my petrol bar has gone down just a much lol, I've done 85 miles so far and its just above the half way point, is that good? I normally see 200miles a tank.
