In the dry I run, 2,2bar front and 2,8bar in the rear. I also run 205's in front and 195's in the rear. This reduces underster. If you use 195's all around try 3bar in the rear and 2,2bar in front (HOT).
In the wet (yes R888's are good in the wet) I increase pressure in front to 2,4-2,5bar and keep the rear at 2,6-2,8.
All these pressures are HOT pressures, a good tip is to write down outside temperature, track, conditions and starting COLD pressure each time on track in this way you get a feeling for the tires. Correct pressure is critical for grip and wear. Start out with 1,8-1,9 COLD in front and 2,4-2,5 COLD in the rear, start easy and gradually work heat in the tires for some laps, go in the pits and check pressure (let air out) repete this until you have even pressure on axles and stable pressure.
Good luck
