Electronics Gurus Help.
Car  Bumder With A Buffer
I know a couple of you lot are in the same profession so wanted to ask a question.
Im after a switch. It goes in the handle of a lawnmower to switch it on/off. Needs to be mom on though.
Now I can find a switch the exact same size that fits inside the handle of the mower but fcuked if I can find a momentary one.
Specs as follows...
Original Is a Kedu HY12 series. DPST, Off - (mom) On.
Looks like this
Best info I can find on the proper specs is here as the Kedu site spec sheets aren't kept online anymore..
http://www.phaseda.com/switch/HY12_rocker.htm
Farnell, RS, etc etc dont stock anything like this only normal OFF-ON in the EXACT same size etc which is guttering! :(
Seems you can only purchase the whole handle switch assembly for £25 (from limited places though) and fucked if Im doing that if a £2 switch is the problem.
Anyone seen something similar around they could recommend? Failing that im just gonna find a similar switch and mod it so that it can work in the handle.
Looks similar to this switch i just found it on ebay try also amazon you might find your luck. the switch is just very easy to find but the switch assembly is giving me a hard time looking for something similar around. i need some guide or diagram also. any help will be appreaciated. a wiring diagram for cliosport 172
images
Specs as follows...
Did you get anywhere sourcing this switch ?
My trusty lawnmower has keeled over this weekend with exactly the same switch issue, and I cant find a replacement anywhere.
Just wondered if you'd had any luck ?
Holy thread revival!
Yes i got somewhere...I bought a set of 3 handles similar from ebay for £10 that had almost the same switch in and modified it to fit. £25 plus postage the one place I found stocked the one I needed.
Sod that
I know mental. Plus the switch someone linked above is totally the wrong type. That's a single on off switch anyway not momentary.
