Damage repair help! (pictures)
Car  clio 1.2
Hey guys, just got a few dents and dings in my car and was look at an approx cost on each repair, The one on the boot is my main problem, how much is it to get some new black plastic for the back? and to sort the boot dent out, Im sure its near some entry points so that may help!
Cheers guys
Fooking hell how did that happen?
You'd probly need a new bootlid/back bumper tbh not sure about the rest get some better pics up
Was in the school car park, some tool thought it would be funny to sneak up in his land rover defender behind me - I looked back nothing was there, but he had come around a corner and his tow bar just dinked into the back :(
The plastic part is roughly £30 from renault.
The boot will repair with about 4 hours labour and paint time + materials. It's only a half boot so you should dave money there.
Roughly 7hrs at £30 per hour. £50 paint met.
The quarter is 4-5 hour repair as it has taken the moulding in with it, the inner trim will need removed, you could actually do that one yourself and make it look a lot better. If you are painting the quarter then you will need to blend the door.
Roughly 10hrs + £100 paint met.
Bonnet about a 2-3 hrs repair.
6hrs + £60 paint met and that doesn't include blending the wings.
I'm an expensive assessor.
ok cool! thanks, how much would a boot-lid be? surely it could be removed with that "paintless dent removal" technique as it is near an access point?
Sam.
1. The paint is marked
2. It's badly dented
3. A paintless dent removal guy wouldn't touch that.
It's actually bent the frame of the tailgate.
The quarter one could be removed probably.
You're welcome. Look in the local yellow pages or something and it should have little independent garages. The job will never be perfect but a lot cheaper than what I quoted.
Get paintless dent removal to quote you. Won't cost you anything.
Cheers! Is there an official renault parts site? Im having a bit of trouble finding it!
No you need to phone up your dealer what prices do you want?
Yeah really easy.
Boot lid new will be over £150 plus all the glass fitting.
Phone the local scrap yard and get a price. You'll probably still have to paint it tho.
not really, bit of a pain in the arse to get the wires to them as they are on the car and not the lid so need threading down the edge of the boot to them but if you can get some welding wire then push it through where the wire needs to go, tape the wire to the welding wire then pull it back though and apart from it getting caught here and there, it should make it easyer than trying to push it through.
also when fitting it, dont just tighten it up and slam it shut. do it slowly first to make sure its not catching anythin and all lines up nice with the other panels and the striker is catching properly.
