Exhaust Heat Guard Bolt Size?
  Clio 1.5dci
(nuts not bolts! oops)
Hi,
I know a 10mm spanner will fit around the nuts, but i don't know how that translates into nut size?
I want to get new ones to replace the rusty ones when i take them off.
Any ideas?
Thanks, Dan
  Clio 1.5dci
The exhaust one :) although after I took off the rusty bolt and replaced it - it didn't cure my rattling noise.
What is the item I've highlighted in the photo? because apparently there's a nut missing and needs tightening up.
Do you know what tools, nut i need? I can't see down the holes because of the angle.
  CLIO PH1 172
i also want to take my fuel raill guard off (to polish it) is it just a guard ? so a case of unbolting it and it will come straight off ?
  Golf GTD Mk7
two bolts, job done! Put the bolts back if you're leaving it off though. Bolts are deap in the holes in the front of it
