I had the car up in the air the other day, For changing the springs, I did plan to have a look under the car for the hanbrake asjuster but it got dark...
Where abouts is it? Theres a few heatshields.. Can anyone let me know which its under?
as above you need to remove the heat shield around the cat/centre section area 4 bolts then its there. if the cables dont teshion evenly i would ajust the pads in the drums. ull be able to tell the bracket shoul be levle and not pulling towards 1 cable more than another
dont adjust it by the cable unless you wanna fuk up your shoes, remove the drums and adjust that way, or the way i do it is to look through the holes for the wheel bolts and adjust with a flat blade screw driver.
