H HTFC Mar 24, 2010 #1 where to stick my cliosport.net sticker. was thinking under the centre brake light. hmmmm Last edited by a moderator: Mar 24, 2010
timmmah Car Formally Clio 182 Mar 24, 2010 #9 Jordi17 said: on the right hand side opposite the renault elf one Click to expand... Yeah that's what I done. If you put it under the brake light all you see is an inverted sticker every time you look in your mirror
Brian ClioSport Admin Car LY 220 Trophy Mar 24, 2010 #11 Where ever you decide to put it, just make sure you take your time (and read the instructions) And I expect to see a pic of it successfully applied!
Rob ClioSport Moderator Car 650 - V8 Goodness Mar 24, 2010 #12 Brian, I royally messed mine up, light was fading and I was rushing, I peeled the wrong piece off and screwed it up (uber fail) Although I managed to save my bacon by applying gaffa tape where the old piece used to be, and starting again, lol! This method should be included as a note at the bottom for those who don't read, try, fail, then read
Ian_s Car E46 M3 Mar 24, 2010 #13 timmmah said: If you put it under the brake light all you see is an inverted sticker every time you look in your mirror Click to expand... Inverted? Really? If you've got one in the rear window go and have a look at it in the mirror
