Air Filter
  Renault Clio Campus 1.2
Hi all,
I had my car serviced a few weeks back and only had time to look now. The air filter was changed but i didn't check it. Today, took the casing off and I can't put it back on again. I cannot get the filter casing to click at the 4 points. Is there a special way?
BTW it is a Clio Campus 1.2 8V 2006.
  Clio sport 182
you can take the hole airbox off and try fitting it that way i find at work using a little lube on the rubber seal helps they are quite fiddly to re fit
Thanks, But I can't quite get the 4 lugs around to clip around. I did want to remove the whole airbox but as you can see i'm useless. I can't even fit a damn airbox cover lol.
If it was misfitted, what should i notive? oh and which type of lube?
  Monaco 172
Haha i had this problem, broken clips. This is the best fix available :cool:
