aftermarket steering wheels
Car  Defender 110
where is the best place to purchase one from, and what size should i be looking at buying for a ph1 172? 300mm or 320mm'ish
im looking for an omp suade sort of one.
cheers everyone
gez
Well I got my Momo one from K Tec, Cost me £200 in the end once you add in postage and the resistors. I'm sure Demon Tweeks will happily take you're money as well! But I would of thought K Tec could get you whatever you want as well.
I went for 300mm as that's the biggest you can get the Momo Team wheel (which is my favourite wheel ever!)
If you're looking at a suade OMP wheel I take it you want it for track days / fast road use so I'd suggest 320mm as 300mm may be a bit small... I just potter about in mine so it suits me down to the ground and looks amazing imo!
cheers for that input mate :)
also, when ive been looking at the boss kits im not sure about all the studs/diameter ect that you need for the after market wheel to fit.
120 all in for this one mate
I would get a momo boss if i was u mate.i had omp at first and it wouldnt fit properly as the hole wasnt big enuff for the wires to get through.all wheels fit as ther the same 6 screw spacing
Yes mate, the wheel is from the omp shop, i did get the hub aswell with it but the wire was to small fr airbag wired to go through so sent it back and got a momo hub instead.and yea ther all the same size no matter what make
I love the look of those Sabelt ones and obviously looks very OEM+ however, after a few thousand miles they go all shiney and look OLD...
this is the one i might buy. is 330mm a decent size? and is it the right boss kit with the air bag wire?
hi iv just bought omp boss/wheel is this easy to fit, an could anyone tell me some quickish instructions?
thanks:o
