rota wheels
Car  172 cup
hi, i have rota grid 16's that i had on my civic. the fitment is 4x100. what do i need to make them fit the clio, is it just spacers to get past the brakes? i know they do fit because i have seen them on a clio sport, thanks
you need to measure the center bore of the rota.
civics have 56.1 mm and clio has 60.1mm so unless you used spigot rings on the civic they wont fit........
If the Civic has 56.1mm and the Clio 60.1mm you'll have to get the wheels bored out to fit.
yeah thought that, them and spacers, you think thats the only thing al need?
If you didn't use spigot rings to fit to the Civic ie. if they were the right bore for it, they won't fit the Clio. If you used spigot rings on the Civic, there's a chance they'll fit the Clio with thinner/no spigot rings.
i defo need spigot rings.i used spigot rings on the civic. yeah tried them on, there hitting the brakes because of the offset. will any spacers do, just ones like you can buy in halfords?
Do you know the centre bore of the wheels?
Don't use halfords spacers they're sh*te. Get Eibach/FK/H&R hubcentrics or don't bother, unless you want your wheel falling off.
