Fitting: Front Strut Guide Request
  Renaultsport Clio 172 Cup
Hi Guys,
Can anyone do a Guide on how to fit a front stut please?
Mods: Please refer this post to the relevant section.
Regards,
Tom
  i3
Is there not one in the guide section?
Its part of the lowering process if you are fitting springs.
front
BEFORE you jack the car up undo the 2 21mm top mount caps under the bonnet (soak them in WD40 the night before) don't remove them completley yet
jack up BOTH sides of the car (do this off the box section under the car, NOT ON THE SILL!)
remove wheels
undo lower shock bolts (21mm or 19mm, i can't remember, i've been on the stella)
when the shock is free, remove it by pushing the lower part towards the rear of the car (between the steering arm and the wishbone)
once off the car undo 17mm top nut (if its a 172/182, there's no need for compressors)
bang on new spring and reverse the above process
