Tom ClioSport Club Member Car i3 Apr 20, 2010 #1 Compressor kicks in, but no cold air. I'm guessing its got a slight leak and needs a Regas. Do those Halfords cans work? Or shall i just get it done properly for £25
Gally Formerly Mashed up egg in a cup ClioSport Club Member Apr 20, 2010 #3 Get it done properly Tom and the re-gas dude should test it with a compression test, leaks are very common when not used. Seals dry up ect... £25 seems very good Roughly £45/50 up here.
Rob ClioSport Moderator Car 650 - V8 Goodness Apr 20, 2010 #4 Who does a re-gas for £25 Tom? I got quoted £50 + VAT, but I have no idea if mine is dead or not or just out of gas
Rob ClioSport Moderator Car 650 - V8 Goodness Apr 20, 2010 #5 gally said: Get it done properly Tom and the re-gas dude should test it with a compression test, leaks are very common when not used. Seals dry up ect... £25 seems very good Roughly £45/50 up here. Click to expand... Are the leaks £££ to fix? Or is it all relatively simple? Mine hasn't worked since I got the car, and I have no idea how long it hasn't worked for
Tom ClioSport Club Member Car i3 Apr 20, 2010 #6 My mate. He wanted £85+vat. One blank stare later...
Gally Formerly Mashed up egg in a cup ClioSport Club Member Apr 20, 2010 #7 Sometimes it's as simple as the air con guy just replacing the seals, like 5p seals. The dryer may be goosed or the leak could be from the rad or pipes. Rad/pipes = £££'s!
Rob ClioSport Moderator Car 650 - V8 Goodness Apr 20, 2010 #8 Hmmm, interesting, I'll give Two Techs a crack at it, see if they can get it going...
Gally Formerly Mashed up egg in a cup ClioSport Club Member Apr 20, 2010 #9 Just be glad it's working as when the pump goes! ££££££'s!
Tom ClioSport Club Member Car i3 Apr 20, 2010 #10 Condenser is £125 Dryer is £35 Evaporator is £125 Compressor is £250
Gally Formerly Mashed up egg in a cup ClioSport Club Member Apr 20, 2010 #11 Ah that's about the only thing renault do cheap. Also consider the time to fit some pipes all the way back to the bulkhead. £700 for a air con pump on that last Audi I did!
Gally Formerly Mashed up egg in a cup ClioSport Club Member Apr 20, 2010 #13 Thought as much! Autoclimate?
Gally Formerly Mashed up egg in a cup ClioSport Club Member Apr 20, 2010 #15 Ah they seem to do a lot of stuff, going to have to get a price list off them.
Rob ClioSport Moderator Car 650 - V8 Goodness Apr 20, 2010 #16 gally said: Just be glad it's working as when the pump goes! ££££££'s! Click to expand... I don't know if it is working...
Gally Formerly Mashed up egg in a cup ClioSport Club Member Apr 20, 2010 #17 Like Tom says Euro car parts are good for aftermarket/valeo ect... stuff.
