Air Con issue
Tom
Car  i3
Compressor kicks in, but no cold air.
I'm guessing its got a slight leak and needs a Regas.
Do those Halfords cans work? Or shall i just get it done properly for £25
Get it done properly Tom and the re-gas dude should test it with a compression test, leaks are very common when not used.
Seals dry up ect...
£25 seems very good Roughly £45/50 up here.
Seals dry up ect...
Are the leaks £££ to fix? Or is it all relatively simple?
Mine hasn't worked since I got the car, and I have no idea how long it hasn't worked for :(
Sometimes it's as simple as the air con guy just replacing the seals, like 5p seals.
The dryer may be goosed or the leak could be from the rad or pipes.
Rad/pipes = £££'s!
Just be glad it's working as when the pump goes! ££££££'s!
Condenser is £125
Dryer is £35
Evaporator is £125
Compressor is £250
Ah that's about the only thing renault do cheap.
Also consider the time to fit some pipes all the way back to the bulkhead.
£700 for a air con pump on that last Audi I did!
Ah they seem to do a lot of stuff, going to have to get a price list off them.
Like Tom says Euro car parts are good for aftermarket/valeo ect... stuff.
