172 (phase 1) what pads/discs for track days??
Car  172cup.Mr2TurboStiV5
What's a good set up for track use?? The car will be used on the road as well but mainly track. Id rather keep costs down if possible so no huge brake conversions :-)
can you get away with stock discs & good race pads, or is it better 2 upgrade the discs as well??
Cheers dan
stock discs (Brembo HC are the best and less than £60 a pair)
pads - lots of options, but spend the money here
do the brake lines too if budget allows it
the biggest advantage you'll see if always using fresh disks if you change pad compound. Been surprised by brand new disks and genuine pads being very good when new.
Shitloads of pad options if you're particularly hard on these things
Cheers for the advice, where can I get brembo hc's from??
Thanks again
The CL RC5+ is probably the best pad option for you seems you want to use it on the road and the track. It'll work from cold up to temperatures well above what you'll get to on track so you won't get pad fade and you wont have much dust either. Combined with a decent brake fluid and braided brake lines you won't go far wrong
DS2500 works a treat on road and track.....that is along with braided brake lines and brembo max discs. When I come to changing them I will use the same pad but will try the HC discs.
Having tried a few types, I'd go for the ds2500's. Even if the rc5+'s hadn't disintegrated on me, I would of gone back to ferodo.
