Centre display pushed back?
Car  Jap Box
Hi,
Looking at buying a MK2 PH1 clio, car is fine itself and everything is running smoothly on it. Only problem with the interior is that the display console above the headunit has been pushed back slightly so the buttons are not in place and you cant press them.
Would this be easy enough to fix or would the entire dash need to be removed to put it back in correctly? Anyone ever had this problem before with theirs?
Thanks
Just the little clock? This moves about with the dash top, only a few screws and then you can adjust it easily enough.
I'd be more worries as to why its like that, i.e has there been an electrical fault for the dash to have come off in the past?
Yeah very easy job to fix, few guides on here on how to get the dashboard off, arm yourself with a few tools and you have everything you need :)
Thanks, doubt there was a fault with the dash, dealer is very genuine and showed me around the tiniest of problems with the car. Got people who know him too and they have all told me he is good with fixing anything after buying if it is at fault and free of charge too.
Thanks, I was dreading having to remove the whole dash front etc too, wouldn't have been worth doing if I had to :P
