ICE & Fog Light help :)
Car  Jap Box
Hi,
Some simple questions here I hope. The car is 1999 T reg mark 2 ph1, Grande spec
What size speakers would I need to replace the stock front and rear ones? I also have 6x9's would I simply be able to split the rear speaker cable to run both rear speakers and the 6x9's? Or would I need something else?
Also, where is the best place to earth a sub, somewhere in the boot floor or somewhere below the rear seat?
I have had a look on ebay for fog lights, but none of them look to some with the surround to hold the fog light in place. Does the car have this under the fog covers? Or would I need to find some surrounds? Also is there already wiring there for fog's or would all of that need to be done too?
One last thing :P the center console(thing showing the time, radio station etc) has been pushed back and it looks asif the backlight to is is broken, it turns on and everything but it is really really dim and hard to see. Would the backlight be easy to replace or would it just be easier to try and source a new unit from a scrappy and just plug that one instead.
Thanks for any help :)
13cm // 6.5 inch speakers fit straight in.
Amp+Sub ive got mine fitted in the boot.
Some cars have wiring in, you'd need a stalk and some fuses i think.
Thanks, 13cm all round car, or just front sizes?
Can someone clear up if I can split the rear speakers to power the 6x9's too please.
Ill have a check for wiring, is the stalk control hard to source?
Thanks
Thanks
13cms all around.
Id personally ditch the 6x9's.
Cliospares should be able to sort you the stalk
13cms all around.
Thanks
Got them as a present from the GF, she would be quizzing me if I were to not put them in :P
Ill give them a bell sometime in the week then.
Thanks again
the stalks from cliospares? :S do you have no stalks and want them in the car or want them for an aftermarket stereo?
Id assume id need them for the fog lights as the normal ones dont have the button on them? Or am I wrong?
