172ff and cup drive shaft's, same length?
im going to 172 track my mk1, ive read before that the cup has a wider track to a FF is this true? are they the same length ? and are the hubs the same?
4 different shafts
Only ones i've found to be interchangeable is 182 with cup pack, and 172 cup, and even then they're different as the cup doesn't have a center bearing
the cups track is wider the wheels are a different off set too do this ;)
common misconception fella, front track is 20mm wider and rear is 10mm wider, so unless they used different wheels front to back, the offset isn't the only factor at play ;)
