Saving JPEG's in PhotoShop CS4
Car  "Navy" N17 TWO
Can someone please tell me there is a quicker way to save files as JPEG in CS4 ? :)
I'm having a time consuming battle editing photos, adding a border & my name then having to save every one individually, select format and then quality etc.
Then when you do save it, it will ask you to save again when you close the file :S
Am I a t**t and doing something wrong or just taking the long road home with this?
Trev
Record an action to do it. Open the action window, select record and then apply the changes and save instructions to one of your images. Then press stop. Then select the folder and the action in File > automate > batch. Or just press the play button for the action and work on a file by file basis.
Tried a recorded action on a few files, but it saved the file as a JPEG without saving the changes - baffled.com lol
Your actions writen/recorded wrong then by the sounds of it. I'm at work so can't get you a copy of mine...that said though I've just installed CS5 and can't import my f**king CS4 actions so I've got to re-write them all. :mad:
Ok got it going.
When i record my action it records the folder that file is sourced in, and saves everything to that folder, and saves all the files as "copy"
Is there a way of changing that? :)
Tried the batch method, which overwrites the file with the file name I recorded the action with, therefore I'm losing photo's :mad:
P*ssed off now TBH
P*ssed off now TBH
Select a different destination folder in the batch window !!!!
Or change the file naming to 4 digit + extention, and then when you do your recording record save as '0' at the end, not save.
It's so much easier, doing this.
Hey ?!? Reading up i understand you grasp how to record your own actions.. so make sure you use save as at the end. Stop recording.
Then go to file, automate, batch, then change dropdown on the destination bit to folder, change the filenaming and your done.
Note: I do use CS2 on both mac and pc, but i can't see that it's changed much has it ?
Think I've got that sorted now - was doing my head-in earlier today so I gave up and went for a drive lol :o
Nope!
Numpty here is about to give up again! :banghead:
I have seperate actions recorded for a border, a logo, and another to save as JPEG
When I use the save action it is still using the filename the action was recorded on, and overwriting the new file with it :mad:
Deleted that and now have this one, then created a new folder for using the batch process and it seems to work.
When I use the action on it's own, it disrupts the files in the origional folder :S
My action is
SAVE
As: JPEG
Quality: 10
Matte: None
In: C: Users\Tigger\Desktop\Night Out\With Copy
Trev
save for web and theres the option, as above, you can record all this.
Recorded separate actions ? You do it all in one, then stop recording !
You can't go wrong with what i said. I'll do a SLOW run down (this is not the only way)...
Make two new folders call the first one something like “Trev's images original” and the second something like “Trev's images edited”… copy across you photos into the original images folder.
Open Adobe Photoshop and open one of your original photographs.
On the top menu bar go:
Window>Actions
At the bottom edge of the actions window hit the folder button to make a new folder to store you newly created action in call it “Trev's actions”.
Hit the button that looks like a post it note for a new action call it “Trev's edit”.
Hit “ok” this starts recording the action, now any thing you do Photoshop will record.
Start doing your adjustments, image>adjustments
Then do image>image size
Then apply any creative filters you wish...
When you have finished creating your style go:
File>save as, select JPEG from the drop down menu and name the file 0 and save it in the “Trev's images edited” folder by hitting ok and close the file you have just saved.
Now hit the square button at the bottom of the actions menu to stop the recording.
To run the action from the top menu bar go:
File>Automate>batch… in the batch dialogue box use the “Set” drop down menu to select “Trev's Actions” then select the Action “Trev's edit”
Under Source: folder hit choose and navigate to “Trev's original images”
Next to “Destination”: use the drop down menu to select folder then hit choose and navigate to “Trev's images edited”
Be sure to click the green arrow on in the “Override action” save as Commands” box.
Under file naming set the first two boxes to “4 Digit Serial Number” + “extension”
Then hit ok and Photoshop will then run the Batch for you and alter all your photos in the way you have told it to.
Sounds almost as simple as this thread makes me look haha :o
So say I record an action to include my name, or a logo/slogan.
What happens if you wanted a different position in different photos? :)
It's not a batch process then is it, lolz.
It's like you can't crop photo's differently because it's not a generic action then, it's unique, hence defeats the whole object of this thread and your question.
I know a plugin called Mogrify is available for Lightroom which does what you want. Not sure on its support on CS4
Well yeah, still wanted to know how to save images anyway without having to go through them all 1 by 1
So much to learn in photoshop....God help us (i.e. ME) :p
