182 RS - Cruise Fault
Car  PH2 RS
Hi,
I am writng from Turkey. First of all sorry for my bad ing.
My problem is that,
A while ago, I noticed that my car's cruise control is not working.
When I push the button down, orange symbol is lighting and when I press on R button on the steering wheel, car is limited the speed.
However,
When I push the button up , the green symbol is lighting but when I push the R button on the streering wheel , car is not set the speed.
Do you have any idea what should be happened?
'R' stands for return to limit speed/cruise speed.
So if you have switched between 'limiter' & 'cruise', you will need to set the speed using the '+' button before it will hold your speed on the 'R' button.
Hope that helps.
Sir Dave,
Thanks for your attention but I tried all variations and buttons are working but still not set the speed.
Is re-map can occure this problem or not?
