Paddy_g46
Right, I got my engine out today and started to swap bits over etc, I have hit a few problems/misunderstandings. Please help as I want to crack on with this in the morning!
Here we go!
I swapped over what I could of the aux set-up but I am not sure I used the right bits etc.
I basically stripped down the Mk1 and then the 172 and tried to bolt on what I could, I wasnt really sure what alternator bracket to use? :?
Here are pics of what I have done:
As you can see I have used the mk1 brakcet that normally bolts to the inlet manifold in 2 places to hold the top of the alternator. I this correct?
Or should I be using this bracket somewhere?
I cant see how this 172 item will fit as the faces are not straight? :?
This piece came off the mk1 from behind the power steering pump but I cannot get it to line up with any holes on the block and it seems like It does not serve a purpose? Is this correct?
Also when changing over the set-up do I change crank pulley from the 172 item to the mk1 item? I tried to see if the original belt was long enough to fit on and it is not? I can only put this down to the larger crank pulley? Or do I need a different belt?
Finally, for those had have fitted the sort clutch conversion. How exactly do these pieces fit on? I have all the bits needed, 1 bolt 1 nut 1 cap, 1 brass bush, 1 brakcet and 1 fork|
I cant work out how the bracket fits on?! I know you need to use the brass bush but it seems like I would need 2 of them? Either that or some very large washers?
I know this may be confusing but I have tried my best to explain it!
Thanks!
Here we go!
Thanks!
