Is a UCH even repairable?
If it's got an internal fault surely it makes sense to replace it?
BBM reman can repair alot of electrical things.
Whats the fault with the car?
not sure if you're the chap i replied to in a previous thread above cutting wires....?
anyhoo, have you disconnected the alarm to see if this stops the hazard lights, that would be cheaper than anything![]()
just a thought, i dont know if the alarm is linked to the uch, but if it is, and you're taking out uch fuses, that in turn would stop the alarm having any effect on the hazards
My dad seems to think that I must have knocked a wire out of place when I was looking behind the dash, causing the satnav wire to become dislodged or something. I'm not too worried about that ATM though as I can live without it. I'll have a play about with it in the week.Never heard of that one. I input the code via the stalk controls with the wheel on the back and the bottom button. Check all the fuses once again mate.
Oh and to cure the hazards problem, you will need a new alarm unit.
how did you sort the problem out, is the alarm disconnected at the moment or was it a case of unplugging and plugging in again?
Have you had the headunit out at all?
Seems coincidence that your hazards and sat nav screen have both been playing up seen as they are both in the same area.
The screen not coming on could be a simple loose connection inside the dash top. Have you had the dash off?
