Anyone with a 200 cup, quick favour please.
Car  RB Clio 200 Cup
I have requested some parts for my new car which is currently on order (200 cup) which is yet to arrive, however they I have been asked chassis number which at present i dont have as i dont have the car (why they cant just order from car type i dont know..?!).
Could someone with a 200 cup please PM me their chassis/VN number so i can use it to order the parts please?
Thank you.
I will have one for a FF 200 if thats any good if its a generic part to both cars
can get it around 6pm
S
What parts do you want? I'll give you the part numbers.
PS. They can look up the part you want without a vin/reg number. Sounds like he's either poorly trained or lazy
Hi,
The parts I am after for the 200 cup are:
- Set of door handles (n/s and o/s)
- Full set of door mouldings (n/s and o/s)
- Wing mirror cases (n/s and o/s)
Basically i am going to get all of the above sprayed to match the car (racing blue) by a body shop, so if any of the above are listed with a 'primer option' then i'd prefer that part number for each part..
I wanted the above as spares incase i decided to go back to the matt black (as the 200 cup is standard).
Cheers.
Why not buy the above parts from a non-cup 200? They'll already be smooth, and easier to paint.
Very good point, i assume they will all fit?
'The Boosh' could you get me the part numbers for the non-cup models (so they are primed alrdeay).
Cheers.
Handles might be a problem. They have the buttons for the keyless entry. I'd assume they'd be a straight swap too.
Sounds like the easiest option then is cup handles and then everything lese non-cup (so its primed). lol.
I think on the MK3 Clio's, you either get black plastic handles, or silver handles with buttons. Then again I don't think the GT has keyless start etc. Something to look into.
Door Handles:
77 01 475 753 Drivers side and passengers side are both the same
Door bump Strips:
77 01 476 435 - Drivers door
77 01 477 317 - Drivers door - rear
77 01 476 431 - Passenger door
77 01 477 316 - Passenger door - rear
Wing Mirror cases:
82 00 801 908 - Passenger side
82 00 801 906 - Drivers side.
On a side note, you could PM "Wests Renault" who will provide you easily with the parts you require.
I'm not putting a price next to the parts as they vary so much dealer to dealer, but they come out on average at about £30 per part (apart from the door handles which are about £15 per side).
No fella, no buttons on here
Door Handles:
Door bump Strips:
Wing Mirror cases:
Thank you mate,
It appears i need to find a model which would have pre-primed handles and that would be non-keyless entry (as the cup is) and then i presume a model which would have pre-primed door mouldings and wing mirror cases. Pre-primed so that they will be much easier to spray (or are meant to be sprayed anyway).
Cheers.
Rob keep us updated on the Rub strips as im also very interested in getting these done in a gloss black. oh and the mirror covers :D
Paul
Paul
Will do mate, i am just doing my reserach on models which will have the items pre-primed, once i have some answers i'll post up.
