valeo clutch price 2002 172 sport
Car  172 , 200sx
been quoted £89 plus vat for the 3 peice kit from MVC but that seems cheap could it be the wrong clutch, new to clios, are the different fitments
doing the clutch, both driveshafts as im getting bad vibration under medium to heavy acceleration and the drivers side has play and sounds dry, the clutch being a might as well at the same time, also fitting powerflex bushes to the bog bone gearbox mount as the gear stick moves back and forth 25mm when going on/off throttle
just need to find out the best gearbox oil to use
Uprated bushes wont help reduces vibration, theyre stiffer so could make the vibration worse?
the vibration is from the warn CV joint on the drivers side driveshaft, the bushes are to remove movement in the gearbox mounting so reducing wheel skip under hard acceleration
