help buying gear stick gaitor and handbrake aftermarket
Car  172 turbo
hi basically i have a proper stripped out 172 2002 and i can measure the lenghth of material i need but how ever on demon tweaks none on there gaitors have lenghts and i do not want to end up buying one to short, i basically have bare metal to the top of the gear nob exposed and wanted to rivet a gaitor from the bottom of the plastic gear stick part, and just get a plain gaitor for handbrake i have left on the plastic handle tho cheers please put any links up you have used same idea?
Hello. I have stripped out my 2002 172 interior and would like a replacement gear gaiter for it. I can measure the length for the required material however Demon Tweeks don't appear to have measurements for their gear gaiters. I don't want to buy one that's too short. I would like the gear gaiter to go from the bottom of the shifter up to the gear knob. I would also like to get a plain handbrake gaiter that will fit under the plastic handle.
Can anyone help me, and supply links if any of you have done this before?
Thanks.
:approve::approve::approve: A+ (Y)
Thanks.
