Oxygen Sensor.
Car  clio 182 black /gold
Here is another question about this sensor. I think mine is on its way out. The engine light is on and highlighted here http://www.obd-codes.com/p0130 Are they easy to change? Also where under the bonnet is the connection so i can check that 1st. Thanks :).
Mines were an absolute b*****d to come off to the point ive left it - im getting it booked into my local exhaust guys in hope they will get them off :-(
sometimes sitting at around 5500 rpm in 2nd for a mile gets the emissions right up to temp and can burn off tar/carbon of the sensor,cause usualy driving like miss daisy or car not used a lot,might help before you go getting the blow torch out to heat up sensor just to get it out.
I was jump starting a diesel. Sat there with the foot on the throttle for a few mins. I wonder if this has some to do with it.
