Blur?
I have a canon 450D and am just starting out, but ever time I take a photo of action, movment etc all the pictures come out blurry can any one help?
Thanks Andy
You need a faster shutter speed. It obviously depends what you're shooting.
You can shoot slower if you're panning and intending to get the background blurred but the car in focus. Otherwise, you just need a faster speed. 1/1000th. Try that and see if it's still blurred.
Revels - With the blurred background effect when shooting a car for example, how do you keep the car in focus, but make the background blur? What is it that stops the car from blurring aswell?
It'll be Tv on a Canon.
It maybe that you don't have a fast enough lens - You might need some flash (or other light source) in order to expose the shot as you want and freeze the action.
That's depth of field. Have a look at the tutorial on here (or there are loads on the net). There's lots to learn!!
OP - Examples needed.
Are you taking night shots without a tripod ? Are you shaking with the cold ? Do you need a flash ? By action are you talking F1 cars or some dogging down the local layby ?
ar90..: You need to learn about panning. You follow the car, so it's like taking a picture of a stationary thing as you're moving at the same speed as the car (well the lens is IYSWIM).
The blurry shots are shutter speed, the shutter is open for so long that any movements you or the object make, will be captured.
As for some bits being blurry and others not, there are two kinds mentioned above.
Laingo is talking about stationary objects and using the different depth of field to throw objects that are further/closer from your focal point out of focus, the amount of depth can be altered by the aperture, the f-number on your camera, on a standard lens, anywhere from 4 upwards.
The other that Giraffe mentions is using a slower shutter so that when the shutter is open, the background/wheels are moving but by moving the camera and keeping the car in the same place relative to the camera, the car remains in focus. This is quite tricky though but there are some good tutorials on panning.
