Dont really know if its been mapped as it run like a bag o sh*t. i will let it get really warm and give it a go. why will it not do it from cold has renault wrote something in to the ecu
Oh my f**king word. Have some mechanical sympathy. I thought I had no sympathy giving my gearbox/clutch hell but this takes it to the next level.
Ok then mate explain. what you mean
Oils thicker when its cold. Its lubricating properties are much less. You rev the tits off it when its cold the oil wont lubricate properly, damages bearing surfaces over time, etc etc etc.
When mine was RR'd, the limiter was at 6800.
5th?my ph1 when its warm revs to 7.2k in 1st and 2nd gear, then 7k 3rd, 4th and 5th.
^maybe true for other cars but not for the clios
fuel pump - stock is fine upto 240bhp
FPR - is in the tank and doesn't need an ajustable one
cam timing - unless he has deleted VVT then you use stock timing setup
plugs - stock are fine, iridium are a waste of cash
i'd suggest you start by changing the coolant temp sensor and have the cam timing checked by a renault specialist
stock rev limit is 7200rpm, if its only reving to 6500 its "normally" the coolant sensor at fault
with a map you're safe upto 7800rpm
