advise on uprated xenon headlight bulbs
J
jezzerbing
hi
need some advise. i want uprated xenon bulbs
not sure what colour and power
anybody got any recommendations and price wise???
thanks for looking
jez
J
jezzerbing
thank you
can anybody put on a link to a good set of bulbs
im not too sure what type bulb (h1, h2, h7 etc))?????
Christopher
  Z4M
D2S.
I'm running pimp-spec 8000k's.
Not as blue as you'd think...
jenic
Do you have xenon light units at the moment? Trophy didn't come with them as standard.
If not i'm presuming you want uprated halogen lamps rather than xenon lamps.
Christopher
  Z4M
You'll need different lights if you want to fit xenons to a Trophy, yeah.
They're easily available though. Plug and play, they can be fitted in under an hour.
You can't get any brighter than the standard 4300K colour temp. Anything higher is bluer but won't give as much light on the road, I had 4300, 6000, and 8000K in my 172 and settled on 6000k as a good balance between light and colour.
jenic
In that case you need D2S lamps as stated.
You can get them from as little as £20 for somewhere like www.hids-direct.co.uk
Obviously more expensive one's should be better quality/last longer.
J
jezzerbing
ok thanks mike and jcc
d2s 6000 are what i will get
98% of people say 6000 are the best option
  BMW F21 125d
Has anyone purchased from HIDs-Direct?
£17 for a pair of D2S 6000k over £56 at HIDs-4-U....
Experiences/Opinions? I can't see how HIDs-4-U can charge 3 times the price of HIDs-Direct
J
jezzerbing
Anybody recommend any good looking sidelights bulbs to go with updated xenon bulbs or leave them standard???
J
jezzerbing
I've just ordered a set from hid direct so will let you know when I get them
How they are like.
jenic
I've messed about with loads of different sidelight bulbs, and nothing looks better than just removing them.
  Clio
i put my 8000k 1s in today, give off a lush colour, dont look stupid either give it that vip sorta look
  Clio 182
you remove a rubber gasket, then twist a square thing, and then you have two clips which secure the 'bulb', my explanation is crap, but without knowing what to do it took me 5 minutes to change it, the only problem is the driver side, you have a lot less room to work with, i think it can be done, but it will require a lot of patience and swearing.
A lot of people take the bumper off to switch xenons, but i'd rather do without the hassle.
