Not much work mate,
Remove 32mm hubnut
Loosen top nut and wheel nuts,
Jack up and take wheel off,
Loosen the TX45 screws locating the disc, and remove the brake calliper by removing the 18mm bolts (make sure you add copper grease when refitting
Remove 17mm pinch nut and bolt (could be worth replacing them)
Remove the 17mm bolt from the track rod and remove it (hammer might be needed)
Use a long bar a lever the balljoint out of the hub via the wishbone,
Removed the 18mm nut and bolt that join the shocks to the hub and remove the hub (make sure the driveshafts are loose from the hub and don't pull out when removing the hub! (Hammer might be needed)
Take the weight of the shock while removing the topnut and remove the shock assembly,
Reassemble in reverse order but push the hub into the balljoint first!
Make sure you're careful with the balljoints and rod ends as they can be easily damaged,
And the rears are interchangable between all mk2 (except the v6)
